Reload this Page >
CARF Ultra Flash Evo build thread +
Old 11-04-2021, 04:21 PM
  #151
Rudeboy
Rudeboy's Avatar
I went with 4 socket head servo screws to retain the tail cone.
Since I didn't feel there was enough material at the top for a 3-screw setup.
Old 11-04-2021, 09:56 PM
  #152
Dave Wilshere
No cooling holes needed, but the hole in the rear fuselage/tailcone mating face needs opening to give a few mm all around. The ‘cool wall’ tube should not get too warm with the proper gap between inner and outer pipe at the rear and cooling NACA ducts at the front. It’s how the Thousands of Flashes made are flying (although the way RCU is atm someone probably thinks they know better 😉.)
D
David J Ruskin (11-05-2021)
Old 11-05-2021, 02:49 AM
  #153
jetpower
Well mine is also on it's way ( art scholl scheme)
cant wait for it to arrive and start building
Question witch size of magnet's are used to hold the canopy to the canopy frame while glue dry's?
regards peter
Old 11-05-2021, 10:30 AM
  #154
Dave Wilshere
Peter
8mm x 8mm or 10mm x 10mm work
Old 11-05-2021, 11:23 AM
  #155
Rudeboy
Rudeboy's Avatar
This is what I have now: around 3-4mm of space between the tube and the fuse-tailcone mating face.
And a virtually airtight seal at the rear.
My thrust tube came pre assembled, the outer tube has 4mm of overhang over the inner tube at the rear.
Total overhang including tailcone is about 9,5mm.
I was thinking about magnets for gluing the canopy glass...glad to see I'm not the only one lol
Old 11-05-2021, 01:26 PM
  #156
Dave Wilshere
All good then.
Middle shot is glass with no glue.
Old 11-09-2021, 04:54 PM
  #157
LA jetguy
LA jetguy's Avatar
In the process of putting together my UF.. I came across two sets (four pieces) of items pictures below.. I’m guess it has to do something with fuel tank installation but how ??
Thank you for advising….
David
Old 11-09-2021, 10:09 PM
  #158
Dave Wilshere
In the early days I was concerned the tank would put a lot of load on the Velcro retaining blocks glued to the fuselage, or move around when full, stretching the Velcro strap. These were to go on the bottom of the tank to sit on the wing. In practice we have not had a problem so it’s your choice
Dave
Old 11-09-2021, 10:22 PM
  #159
LA jetguy
LA jetguy's Avatar
Thanks Dave…. I though it had to do with tank installation…. I have decided to use some “Goop” on top of the tank and use some Velcro on the tank so the straps stick to it preventing tank from moving at all….
Appreciate quick response..
BTW .. when will you get your MIG17?…. Danny (F1 Rocket) will be working on mine.. we have the same paint scheme 😊
Old 11-09-2021, 10:57 PM
  #160
Dave Wilshere
On mine I stuck Velcro to the tank that the strap goes over. That stops it moving around. It does need something at the front or back to stop it ‘swinging’ side to side.
Its on the water now, but with container delays in Europe and Brexit mess I’ll be lucky to see it for Xmas. Yes, I know you ‘stole’ 😉 my scheme. It’s one I spent ages looking for.
Next favourite would have been this…
David J Ruskin (11-10-2021)
Old 11-10-2021, 10:52 AM
  #161
jetpower
Double post
Old 11-10-2021, 11:04 AM
  #162
jetpower
Finaly got mine today
and after unpacking in noticed that the thrust tube at the end the the pipe and outer pipe are near flush with each other and that the outer tube is about 1cm inside the tailcone so it will not hold it at the end
Old 11-10-2021, 11:23 AM
  #163
Dave Wilshere
Which tailpipe design have you got? Show the whole pipe. On mine the cool wall was out the back of the tailcone. Have you opened the former hole in the rear fuselage?
Old 11-10-2021, 11:26 AM
  #164
jetpower
it's this one
I orderd it as an accecoiry from the ultra flash page
Old 11-10-2021, 11:28 AM
  #165
jetpower
Again double🤪
Old 11-10-2021, 11:30 AM
  #166
jetpower
Think i'm gonna redril the hole's in the outer pipe
and blank the wrong hole with a smal pop rivet
and the front of the bellmout is flush with the former
I did not have to open the hole in the former at the rear
Old 11-10-2021, 11:45 AM
  #167
Dave Wilshere
The outer cool pipe does not actually need blanking, the small gap will actually work as it is, the difference should not be more than 10mm.
if you move the pipe back till the outer wall is flush with the tailcone, is the carbon bell mouth inside the rear wing former?
Old 11-10-2021, 12:08 PM
  #168
jetpower
Hard to see bud the distance between outer pipe and inner pipe is about 3mm
and when the outer pipe is flush with the tailcone
The belmouth is not flus or hardly on the former
Old 11-10-2021, 12:23 PM
  #169
jetpower
Gone thrue the original ultra flash manual
and it said that the inner pipe should be between 6 and 8mm inside the outer tube
Regards peter
Old 11-10-2021, 01:16 PM
  #170
Dave Wilshere
OK. Thanks
Yes, they are the magic numbers
Old 11-10-2021, 01:20 PM
  #171
jetpower
Thanks dave
Gonna think af a solution for it
regards peter
Old 11-10-2021, 11:59 PM
  #172
LA jetguy
LA jetguy's Avatar
Dave…. I still think the Blue Silver “Scott Cullen” scheme looks better. I went with silver and blue rather than white and blue…. Most probably you will get yours before Danny gets mine…
I’m going with JM250.. I’m guessing Jetcat 220 for yours 😀
David
Old 11-11-2021, 05:27 AM
  #173
Dave Wilshere
David
Yes, mine is Silver. Yep JetCat P-220Rxi
Old 11-11-2021, 07:31 AM
  #174
LA jetguy
LA jetguy's Avatar
David
Look forward to see your MIG17 built thread….
Canadian Man (11-11-2021)
Old 11-11-2021, 07:49 AM
  #175
Canadian Man
Canadian Man's Avatar
David, Depending on when you come up I will have one here as well!
